Old 02-05-2011, 12:05 PM
staylor1650's Avatar
staylor1650 staylor1650 is offline
Default k-341 power loss
I have a 1650 cub with the 16hp Kohler. It will hit WOT and low idle without any problems but it won't handle a load on it. Example, if I have it at wide open throttle and I press the hydro lever all the way forward, it bogs the engine down. That is the only way I can think to put a load on the engine. The carb is clean and its fresh gas. I know it takes some horses to turn your hydro and the hydro fluid has new Hytran and filter. I didn't no if this is a governor problem or a carb problem or if I am imagining things. Any advice will be appreciated.
75 Cub Cadet 1650
64 Cub 100
not cub but its yellow 62 allis chalmers b-10
Old 02-05-2011, 04:39 PM
Merk Merk is offline
How old is your spark plug?
What brand is it?
Had that problem before. I had a spark arcing through the porcelain part of the plug. Only way I found this is running at night.
Old 02-05-2011, 07:13 PM
so would that cause it to run poorly all the time or just under a load
75 Cub Cadet 1650
64 Cub 100
Old 02-05-2011, 07:42 PM
Improper timing will do that too. Here's some info on that.
Old 09-24-2011, 02:34 PM
r.harrell's Avatar
r.harrell r.harrell is offline
Not sure if this will help but mine did the same thing to me would idle at low idle or wot all day long but a load would cause it to shake eraticaly and bog down. I replaced the points and set the timing and it solved the issue.
Old 09-24-2011, 08:36 PM
If You have the engine @ full rpm and push hydro lever FWD it should bog the engine a bit, then the govenor should open up the throttle to establish the full rpm again,as you gain ground speed.
If it is faltering and stumbling and not coming up to rpm, try opening the main jet screw a 1/2 turn (CCW viewing the head) and see what it does noteing the position so you can return to that setting in the event that isn't a problem.
Old 09-25-2011, 12:40 AM
mattkarr mattkarr is offline
A bad head gasket or carb gasket could be causing a lean condition but it would run hot also a sticky valve could cause this too.
