Old 10-11-2011, 06:38 PM
krhoover krhoover is offline
Default Made a hitch
If I ever get the 1450 to run, I'd like to try this out with the Brinly plow I got at the scrap yard, needs paint yet, but I think it will work.
Old 10-11-2011, 06:47 PM
If I were you I would replace those clevis pins with a rod that goes all the way across...you are going to destroy either your lower 3-point bracket or the sleeve hitch adapter the way you have it now. Notice the angle of the clevis pins...
Old 10-11-2011, 07:59 PM
Those are just bolts in there now, just to hold it up there for fit. I was going to add another longer adaptor plate behind the one on there, and slip the hitch adaptor arms into the space between the two. Will one long rod be just as good?
Old 10-11-2011, 09:07 PM
Rales Rales is offline
Nice job, ive been thinking about making one also but I am not able to find the 5/8 ID pipe. Where did your source your materials?
Old 10-11-2011, 09:25 PM
The steel I just had around. I also happened to have a rod that had a .625" hole in it. Lucky I guess. There are drawings and pics on here, thats what I worked off of.
Old 10-11-2011, 09:55 PM
Either of those will be fine.
Old 10-11-2011, 10:04 PM
Nice work krhoover
Old 10-11-2011, 10:43 PM
Nice work krhoover
I second that!
Old 10-11-2011, 10:51 PM
LarryW's Avatar
LarryW LarryW is offline
I dont see what you made? Everything looks original to me, lol. Nice work!
Cub Cadet 147 2050041u340160
42" Mower Deck, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade.
Cub Cadet 1872 SGT
60" CCC deck.
Parts 129 future plans =ported pump for 147, cast iron rear for 1872,129 frame and steering axle= ?wagon?
Old 10-12-2011, 10:23 AM
Nice work krhoover
I second that!
I third that! Great work!
