I brought home a barn find the other day and after new tubes, cleaning the glue (probably was gasoline) out of the carb and tank.
Checked wiring for bare spots and traded in the dead battery (punched for 2002 purchase). Yesterday began the task of trying to get her to turn over with a key. Found the alternator under the seat and got the diagrams from this forum. The question I have is that the alternator appears to be for the original Cub. [IE: Bat - Gen - F - L] posts. According to the service manual, the one for my 124 it should have [Bat - Gen - F - Ground] on the posts. ![]() Will the original work on a 124 w/o lights? Thanks |
Your regulator should not be under the seat on a 124,it should be mounted on the grill casting above the heat shield.Not sure if the reg will work though...never tried using a 4 post on a 3 post cub.Maybe one of our other members will chime in...
It was just a minor wiring change to accommodate the extra terminal.
<Ground> hook to the mounting bolt next to the regulator ground strap <Bat - Gen - F> all mount normal <L> Not used Initial test seemed good and I will know for sure when I get finished with a internal engine once over.
The "Voltage Regulator" you have, will work. Just insulate and do not use the "L" terminal.
On my Cubs, you couldn't hear a horn if the engine is at WOT!!!
You beat me to it
LOL that's good
