Old 12-16-2011, 03:03 PM
bocephus1991's Avatar
Default Mule Drive pulley Question 2
Was wondering, the mule drive pulleys are 3" dia,would it cause any problems if I use a 2 5/8 dia pulley instead. The bore size and the width of the pulley is the same.
Brian
Old 12-16-2011, 03:45 PM
Hey bocephus1991
I don't think it would hurt anything, but i don't know about getting the belt tight. Going to a smaller pulley would make the belt seem to long. Don't know if you would have enough adjustment to make up for it or not.
If you decide to do it, let us know how it works out.
Old 12-16-2011, 03:55 PM
If you look at the pulley sizes (pto vs mule) a 3" mule is probably running 6000 RPM.
Changing to a 2 5/8 the speed will go up 14% to 6850 RPM.
Where do you worry about how fast that sucker is turning!!??
Old 12-16-2011, 04:20 PM
The RPM's are not the problem, it's well within the ball bearing's range.
You will end up using a different length belt by about 1"---- BTDT on my 782.
I made up a set of solid mule pulleys using a common 203 bearing but the pulley blank was larger so I need a longer belt.
Not a real problem but it becomes a situation that you need to go to a special order belt not something that is avail @ cub cadet.
Old 12-16-2011, 11:00 PM
Well after further consideration,I will prob go with the 3"dia pulleys. Kinda funny though years ago when one of the bearings went out on the mule drive on my 1200 dad got a new one and it was larger than the original,I asked him about it and he was told by the dealer that was what replaced the original,so the mower has ran for 15 + years with two diff size mule drive pulleys on it.
Brian
