Old 12-12-2011, 12:39 PM
thenrie's Avatar
thenrie thenrie is offline
Default 44C blades, will any 44" blades fit?
An ebay vendor is advertising "Gator" blades for a 44" Cub Cadet deck. I asked whether they will fit a 44C deck. They responded that if it's a 44" deck, they'll fit.
Does that sound right? Will a blade set for any Cub Cadet 44" deck fit the 44C?
Trying to get mulching blades. Need to get my leaves chopped up before snowfall.
Tony
Stafford, VA
1650, 682...
Old 12-12-2011, 10:22 PM
The blades from a 44a and a
44c are the same.
Hope this helps...
Old 12-12-2011, 10:34 PM
The only difference between the two decks is the belt size of the PTO pulley on the deck.
Old 12-13-2011, 10:17 AM
thenrie's Avatar
Yes, but doesn't Cub Cadet have a later MTD 44" deck? That's what I'm concerned about. The old Cub decks use blades that only have a spindle hole in the middle. From the pics, these I'm looking at have a spindle hole and two side bolt holes, like an MTD blade, so I was concerned they might not fit, or they might interfere. Some of those MTD decks use a shorter blade in the middle. I just didn't trust the vendor's assertion that they will fit "any 44" deck".
Tony
Stafford, VA
1650, 682...
Old 12-13-2011, 02:22 PM
Call this place. I am sure they will know the differences and fix you up with the right blade.
http://tewarehouse.com/Catalog/Cub-Cadet_5
or go straight to the horses mouth and fill out their order info sheet for the right blade.
http://gatorblade.com/order.html
Old 12-13-2011, 07:25 PM
Vince_o Vince_o is offline
Ill make you a heck of a deal on a set I used one season. how about 3 blades to your door for 50 bucks
Pm me, I wont use them they are just sitting on the welding table taking up vauable space.
pm me if you want them, or to haggle on that price. I think I paid 25 a piece for them cant remember. What ever price you come up with Ill be sure Im cheapier.
Old 12-13-2011, 11:35 PM
thenrie's Avatar
Tell me why you won't use them. I have heard good things about them, especially from those who don't bag their clippings and leaves. I'm mostly concerned with handling leaves before snow falls, but I expect I'll be cutting grass with them come springtime.
PM coming.
Tony
Stafford, VA
1650, 682...
Old 12-19-2011, 08:38 PM
thenrie's Avatar
Vince, I screwed up replying to your PMs, so you probably never got them. Check your email. I want those blades you have.
Tony
Stafford, VA
1650, 682...
