Old 01-08-2012, 03:12 PM
j-man5.0 j-man5.0 is offline
Default 1606 shifter
Anyone know what models shifter would interchange with a 1606?
Old 01-08-2012, 03:38 PM
What is your serial number?
Old 01-08-2012, 06:00 PM
cub1782's Avatar
cub1782 cub1782 is offline
Mine wasn't changeable with a cast iron rear,but if should be inchangable 1050,1806,1535 and maybe some other I can't think of.
Logan Pfeiffer
1986 cub cadet 1606 w/ spring assist, cat 0
1974 cub cadet 149 sleeve hitch
1984 gravely 5665 professional
1979 gravely 8122
1979 gravely 8102
2000 Exmark lazer Z
1978 international 184
Proud to be a member of the FFA
Old 01-08-2012, 10:45 PM
Ill work on getting that serial number tomorrow, its my buddys tractor
Old 01-09-2012, 09:32 AM
Got the serial number its 0320023u
Old 01-09-2012, 09:40 AM
There should be some numbers after the "u". That is what I need.
Should look like this 0320023u737625
Old 01-09-2012, 10:23 AM
0320023u202054 is the whole number, thanks for your help.
Old 01-09-2012, 11:09 AM
OK not sure about the deal with the numbers but after some looking around the 1606 was made in 1985 and 1986. The graph below shows the serial numbers per year for the 1606.
Using those serial numbers on Cubcadet.com's parts site it looks as tho the shifter parts are used on:
1604, 1606, 580, 582 and 1806
The listed charts will help you.
Serial numbers:
Models that share the shifter parts and their serial number rankings:
Old 01-09-2012, 04:12 PM
1604 and 580 have a Peerless 4-speed, so that shifter won't interchange.
Basically any aluminum rear 3-speed shifter should interchange.
Old 01-09-2012, 09:40 PM
Thanks for the info guys i appreciate it
