came across a guy selling a 147 needs a seat and a little wiring issues but starts and runs says the carb could use a cleaning. Below is what the ad states
I have a cub cadet 147 that runs but needs some tlc. It has a 14hp kohler engine with hydrostatic transmission and electric lift. It needs a new seat, the pto engagement handle needs repaired, and it has some wiring issues. It does run fine but you have to jump a wire to the coil. It was like that when I bought it and believe it needs a new switch. The lights and electric lift both work at times, probably just a loose connection somewhere or bad switch. The carb could use a cleaning too. My question is would it be worth $250 if these are the only problems it has.
Rob Harrell New Oxford, PA _______________________________ Cub Cadet 1650 50" Mower deck QA42A Snow Thrower Tire Chains |
If you can hear it run, and the engine sounds good, i would say its worth the money if you want to deal with the wiring issues. Most likely just the switch and some bad connections, but you never know till you start working on it. Just my
Haven't gone to look at it yet but I just finished a project and am looking for another. Didn't want to get into something and it not be worth it in the end.
I hear ya
![]() It looks like a worth while project in the picture. I am sure you will be able to tell more when you actually have it in front of you. Let us know what happens. |
what are the issues these are known for i've only messed with the QL'S never messed with a narrow frame. Any info is help pro's con's on the model would be great.
I myself have been fortunate and haven't had any major issues with the wiring on mine. Grounds were the only thing i went over on mine. Make sure they are clean and tightened.
