Old 04-24-2012, 09:30 AM
sgt.porter's Avatar
sgt.porter sgt.porter is offline
Default 3 point from 109 to 1450?
I've got one of those "will this fit that" questions.
Will the rear lift from a 109 fit a 1450 with little to no mosification?
I've got an offer to buy a 1450 at a good price, but it doesn't have a rear lift. If they're compatible, I'd like to buy the 1450, put the lift on it and make it my garden tractor. Then to keep me from having too many cubs, give my daughter the 109 set up as a mowing only tractor.
Will any/all the parts fit? Or what would I need to buy?
Thanks in advance, the answer is probably around here somewhere, but researching from my phone is next to impossible.
LT1050 w/ 50" deck, 680 Hydro w/ 38" deck, 1450 w/ 50" deck, 109 w/ 38" deck
1A tiller, 42" snow blade (x2), cw-36 snow thrower, H42 snow thrower, #1 cart, 8" Brinly plow, Unk cultivator, Sears rear blade, extra k301, more extra decks and parts than space to put them.
Old 04-24-2012, 10:05 AM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
Maybe someone else will confirm this but a 109 and a 1450 is a wide frame so I think it will work as long as the 1450 is an early one. The early 1450s use a bar that goes throug the rear frame. The newer ones use frankenstein bolts.
1200, 1450, Red 782
Old 04-24-2012, 10:41 AM
The rear lift will work with the correct 5/8" rod, or the Frankenstein bolts. Just depends on your 1450 and which mounting it requires. Now as for the lift bar, I am not sure if the 1x8/1x9 series is the same. I am sure someone else will have that info. If not, you should be able to find the lift bar from one of our sponsors or at xtrememotorworks.com
I used a rear lift from a 129 on the 782 I used to have. I just had to order the correct lift bar.
