Old 05-07-2012, 06:14 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default 982 Running Project Update
My buddy gave me an M18S from an old 1806 and with Roland’s help with the wiring diagram and many hours of plugging away at it, I finally took it for a few laps around the yard yesterday.
I had also took one of the heads off just to see what it looked like and it needs a good cleaning…soon as the carbon is built up pretty good. After doing some checking, I am going to try some Permatex gasket remover instead of doing the “water injection” method. Will post before and after pics when I do this. Did this on another cub I had many years ago and it made a huge difference in how well it ran.
Some things that I found were the fuel pump was bad so that slowed me down. I had originally took the carburetor off to clean out all of the gunk that may have been sitting in there for a couple of years and when the tractor would not run, I immediately thought that it was something that I had done to the carb so I took it off and checked and rechecked everything………2 times!!! Then I thought that I should take the pump off and at least look at it and when I took the 4 little screws out…..one of the little diaphragms fell out and I could see wear marks where it had been getting beat around in there. So I found another whole motor on Craigie’s list so I went and picked it up and took the fuel pump out of it and THAT WAS IT!!..Started right up and ran just fine.
I still have issues with the ammeter that I will work out this week. I did check the regulator and it is fine. The stator measures just fine. Output at the battery when it is at high idle is about 12.8 volts…I am suspecting that I could have a magnet issue that was referred to earlier…..but I really hope not. I have a hard time picking up that heavy motor and setting it back down in there…IT IS HEAVY…as there is never anyone around when you are doing this stuff.
Old 05-07-2012, 06:22 PM
Good to hear that you got her going. Get yourself something like this before you rip up your back.
http://www.harborfreight.com/1-ton-c...ane-93840.html Much cheaper than Dr. bills.
Old 05-07-2012, 06:30 PM
Great to hear you was able to make some laps on it! Awesome pics too!
Old 05-07-2012, 09:53 PM
maddog784's Avatar
x2 - I am getting ready to pull the 18 mag out of my 982 and also had nobody to help when I put the thing in for the first time. I called my buddy and asked if he had an engine hoist - he recommended the same thing that Sam did.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-07-2012, 10:59 PM
Great pics! Glad you got it going.
