Old 05-23-2012, 05:42 PM
newcubfan newcubfan is offline
Default Governor adjustment
guys i need a little help on how to go about adjusting the governor on my kohler k321 in my 149. it does not throttle all the way up and it cuts out only half way down when i throttle back
Old 05-23-2012, 06:28 PM
Here is the Kohler manual that is found in the Tractor Technical Section:
Page 6.27 thru 6.31 should guide you thru the governor setting and sensitivity adjustments.
http://www.kohlerengines.com/onlinec...df/tp_2379.pdf
Old 05-24-2012, 08:44 AM
It's a two person job to make it easier. I did it by myself and it can be done but get ready to have your dexterity tested!
Having the print out DWayne printed out next to you helps!
Old 05-24-2012, 11:19 AM
thanks for the help guys i will let you know how i make out
