I have a good running 12hp in my old 129 with all sorts of wore out parts and am wondering if it will drop in place of the 12hp in the 126. The 126 is weak but has manual and the 129 is a wore out hydro. Any thoughts??
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
you could probably get it to work im not sure though
Should bolt right up, with the driver, and any other gear drive specific parts on the new engine.
-105___ Tiller |
It should work fine. You might have to switch out the blower cover because the coil rides higher on the blower cover on the 129 (due to wideframe) than on the 126. Don't know if the higher coil will interfere with fuel tank, etc. or not. The fuel tank bracket also bolts onto the blower cover for the 126 IIRC (not really a narrow frame guy, sorry
). Otherwise, other than the drive hub, should be a bolt in switch over.
Josh Diesel Cub Cadets........... |
Josh is correct.You will have to change over the blower housing if not the coil wire will hit the glass fuel bowl. The tank bracket will bolt up to the 129 blower housing due to the fact that the clips for the coil wire use bolts to be attached to it instead of studs. Blab blab blah
Thanks guys I thought it would, both are k301A engines, this is a last resort thought. Vince O is coming by Saturday to help me try and get this hydro working right. It shifts fine but all the linkage is very loose and wore out, I'd like to keep them where they are because the 126 is going to peices soon enough. Going to rebuild the engine, replacing most everything in it, shave the head/block, larger piston the whole nines. Then the newly rebuilt creeper, 28" lugs out back and most likely some 4 bolt hubs up front. I am trying to get more ground clearance and power to deal with the clay we have around here. Going to clean up the body/frame and a fresh coat of color. Still trying to decide whether to go yellow/white or orange/white...either way she will be one sheet looking ride, no trailer queen a work horse but just may make it to the show from time to time. For now tho I just need a grass slinger..lol
