Old 02-18-2012, 06:17 PM
Barnabas Collins Barnabas Collins is offline
Default I had 2 rough 42" blades ...so out comes the sawzall
They were pretty rough. One had 1/4" worn off one end of the blade itself and down to the screws.. The other wasn't as bad. I decided to cut them at the screw holes which are spaced at 6.5" so I'm actually ending up with a 55" blade.
Old 02-18-2012, 06:25 PM
That was the other day. I got back on it for a few hours this morning and blasted it and di a little more welding, Did grind the welds smooth on the face of the blades. I'll grind the frame and back side of the blade yet, but not worry about perfection. Hey, it will be white. I'll try and get onto the mounting frame modifications for the super 1762 Monday maybe.
Old 02-18-2012, 07:02 PM
dieseldan123's Avatar
Sweet! Keep up the progress and more pics!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 02-18-2012, 07:34 PM
Nice work Barnabas Collins
Old 02-18-2012, 09:31 PM
Hey BC
If your going to use the blade to push snow, get some 1/8" plastic and pop rivet it to face. Makes the snow slide off great.
Old 02-18-2012, 10:44 PM
I agree with Dan!
Old 02-19-2012, 07:51 AM
Sugarmaker's Avatar
BC,
That's a lot of work marrying those blades together. Very good pictures of your methods. That will be a great snow moving machine!
Sam, I like the idea of the plastic on the blade for a non stick surface.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 02-19-2012, 08:28 AM
Where would one get plastic like that, and would 1/4" carriage heads work to hold it on in Winter and remove for dirt pushing, or would it be ok to leave it on? I've had snow stick to the blades and thought wd-40 or something might help..maybe wax or rain x?
Old 02-19-2012, 11:42 AM
Looking forward to your updates, ABC!
Old 02-19-2012, 12:52 PM
BC
I used 1/8" UHMW plastic. Just do a Google on it and find out who has the best price. I used rivets because I had a full box from my race car. Carriage bolts would work just as well. When I built the plow for my Kubota I used 1/4" because I removed the skin from the plow and only used the frame. It was an old Meyers from a F-150 that I narrowed. Works awesome. Just put it on the Bota for the first time this year and I hope we get enough snow to make it worth while. Haven't plowed snow since I moved to VA and I'd like to get at least 1 storm. OK I know it's the wrong color but I posted the pics just to give you guys some ideas.
