Old 10-29-2009, 11:00 PM
Stitch's Avatar
Stitch Stitch is offline
Default My fab tiller (give advice)
I have a walk behind tiller, with a burned out motor, so here's my plan. I've got the tiller itself, guard and all taken off of the rest of it. The pulley on the side of the tiller that used to attatch it to the motor is still intact and working. I'm going to fabricate a hitch that will fit my sleeve hitch, and find a drive belt that is the proper length to run off of the front pto on my 100. It seems to me that it will work. Will it?
Old 10-30-2009, 12:18 AM
I think it'd be simpler to just buy the correct tiller for your 100.
Old 10-30-2009, 12:59 AM
Stitch's Avatar
I agree that it'd be easier, but I'd rather spend less money, and use what I have. Plus I think it'd be a neat project!
Old 10-30-2009, 06:49 AM
Hey Stitch,
Sounds like it will work, I'm sure a little trial and error and you will have it figured out. :biggrin2.gif:
Get us some pictures.
Old 10-30-2009, 08:37 AM
minncub minncub is offline
You will have to find a way to keep the belt in tension when raising and lowering the tiller. That will probably be the hardest part.
Old 10-30-2009, 06:18 PM
Merk Merk is offline
I would try to find a Cub Cadet tiller it was me. This one ended yesterday on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll...K%3AMEWAX%3AIT
Old 10-30-2009, 08:14 PM
Stitch's Avatar
If I can rig it up so I can run a drive belt from my front pto straight to the pulley on the tiller, will it be safe to assume the speed will be ok to run it?
Old 10-30-2009, 08:35 PM
Well, that depends on the size of the pulley you use on the tiller and what the gear ratio in the tiller is like....without that, who knows?
Old 10-30-2009, 09:20 PM
Stitch's Avatar
That's a lot of thinking. I think I'm just going to do it and hope it works. If not, I'll throw it back in the pasture. No harm, no fowl.
