Old 10-17-2012, 01:40 AM
CubMan70 CubMan70 is offline
Default Question on NF hydro lift
I was looking in the technical section of this site. And i found a manuael for a NF hydro lift and it mentioned some model numbers. and i know my 70/100 are NF. There the same pump units correct?
Old 10-17-2012, 10:59 AM
cub123's Avatar
cub123 cub123 is offline
Yes it will fit, the NF pumps will work on the 70-127. Though you may have to drill mounting holes in the frame, the measurements are in the manual for this if it doesn't have the holes for it...http://ccmanuals.info/pdf/NF%20Hydra...s%20Manual.pdf
