Old 02-10-2013, 12:52 AM
cub149's Avatar
cub149 cub149 is offline
Default Air compressor reg solenoid what do I have??
I bought this from a guy that didn't know what he had and neither do I. It's a MFHE-3-1/2 Festo Solenoid and regulator. I don't understand what the solenoid is for. I plan on just using the regulator and doing away with the solenoid unless there is a use for it. Does the solenoid run the compressor or do something more amazing?
Chip T.
Drexel NC
Old 02-10-2013, 02:45 AM
cubby102's Avatar
cubby102 cubby102 is offline
I don't know a whole lot about them but I would imagine its a auto shut off
Old 02-10-2013, 08:50 AM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
This regulator was probably used to control the air supply on and industrial type of machine that had the air supply valve interlocked to the machine power. When the machine was de-energized or "Locked-Out" the air is dumped and the solenoid closes.
You can remove this section from the unit and it should operate just fine.
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 02-10-2013, 10:10 AM
cub149's Avatar
Thanks, thats what I will do.
Chip T.
Drexel NC
Old 02-10-2013, 10:15 AM
BIGMOZEKE's Avatar
By the way.........when you install this, pay attention to the directional arrow that is on the unit........somewhere, otherwise, it will not work properly.
Joe
1200 Puller[/U][/B]
1864
Old 02-10-2013, 10:48 AM
cub149's Avatar
Yeah, I knew that and the arrows are there.
Chip T.
Drexel NC
Old 02-10-2013, 12:51 PM
does it have 2 or more contacts on the solenoid or 1 (cannot tell ) they should connect to the contact switch to control psi for the tank or it is just a line block
