I have 2 QA36A's and a QA42A and they all have this. I've been wondering what it's about for over a year now so it's time to ask - What are these for?
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights 72, Serial #231093, K161S Serial #C281773, 36" deck 149 & Original Yard art 1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch 1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted 123 FEL and weight box 10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller |
i beleave its the kick stand for taking it off
you should have one at the top too. there is a bar that go's in to lock it all together. put on before you take it off. and take it back off after install.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
If I remember there is a bar that swings down into position for locking the pivot point of the thrower solid to the blower housing. I think the bar has two holes on one end? I know that's not a great description. I think I have a picture on my post about the restoration of a snow blower.
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
http://ccmanuals.info/pdf/QA%2036A%2...s%20Manual.pdf
From our technical section, about page 13 or so,-- it is for the support stand. |
Like ol'George shows is what I use it for. It makes install alot easier.
Illistration 14
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
OK after I saw the manual I now see the correct way that works.
the PO must of just made the bar that was on mine. thanks for the pic Matt.
I downloaded the book for the ones without the last "A" (as in QA36A) which didn't have it. Well, hopefully that will make it easier to mount. I had a time mounting it.
I bought my first Cub, a 129 with the 1A roto-tiller, 44A deck, the 42" front blade, and a bolt-on 36" snow thrower as a package deal from someone who'd purchased a lawn/garden repair shop that was going out of business. That was in 1988. When I couldn't figure out how some of the attachments fit and operated properly, I went down to the 'local' IH dealership (45 miles away) and started purchasing my library from them.
![]() NOW, they can be down-loaded for free from this and a few other WONDERFULLY HELPFUL sights. To those of you who are just entering the addiction, listen carefully to the administrators of this site and go to rhe archives on this site and DOWNLOAD till your printer melts because the manuals, when purchased new, set me back between $15 and $45 each, And I still retain EVERY reciept for all Cub related purchases. ![]() If nothing else, at least read every manual for the tractor/equipment you have/plan to purchase so that you have some IDEA of what your getting/gotten into. Thank you to Only Cub Cadets for being such a GREAT info resource and for so happily sharing the good, as well as the bad, with us. ![]() Happy Cubbing!! FFGino. |
