Old 05-10-2013, 11:04 AM
Cjbdvm04 Cjbdvm04 is offline
Default Belt size for new deck
I'm considering buying this deck to put on my 127 while I finish restoring my original 42" deck. This one looks different from my original deck and I'm wondering if it will use the same drive mule drive belt or would I need a new size. Anyone know what the specs are for this deck? Also, it looks like I'll need to swap the left "spring pin" from my old deck and the right hanger loop looks a bit cattywampus.
Old 05-10-2013, 11:57 AM
sawdustdad's Avatar
Your mule drive should work fine. And I think the belt is the same, too. You can straighten out the spring pin. I've bent and straightened mine before. A big crescent wrench helps.
What deck do you have on your 127 now?
Old 05-10-2013, 12:10 PM
Right now I think I have a 42" deck but my blades are different from the ones pictured above. My deck blades are approx 15" center blade and, maybe, 12" outer blades. The one pictures has a much longer center blade and 2 mini outer blades. Any idea what model deck is pictured above?
Old 05-10-2013, 12:40 PM
The belt for the 127 and the above deck combination is....IH-490489-R2
