Ok so I will admit it - I am a fatty. My problem is on my 1811 my big fat belly rubs the steering wheel. I have moved the seat as far back as I can I think. I loosened up the bolts where the metal spring brackets bolt and slid it back. I dont see any way to move the seat farther back. Anyone have some advice other then start a diet? lol
Its not a big deal but the close quarters with the steering wheel gets to be a pain in the butt a hour in to snow plowing. Weird thing is on the little John Deere lawn tractor I had - I had tons of room, but not on the big ol Cub. |
Krisb:
![]() Without seeing the situation, I would suggest maybe fabricating a mount to allow the seat to go back farther.
Or, if there is ample amount of metal rearward that there is a place to drill new holes,you could drill some further back holes. Another idea is to do what someone did to obe of the Cubs we bought for parts.They made a flat plate just as wide as the springs and made it longer, They slid it backwards and drilled the holes for the seat in it as well as the holes in it to line up in the springs. If I still had it,it would make the description alot simpler to explain..
Pat Harmon Loganton,Pa 128 Cub Cadet 1200 Cub cadet (Red) LT 1042 Cub Cadet 1200 Cub Cadet 165 Hydro John Deere 1941 John Deere H 1950 David Bradley 5756 1952 David Bradley 57561 Super Power |
Went out today and did a temporary fix. I unbolted the bolts that connect the spring steel under the seat to the tractor. I then moved the front bolt holes on the spring steel to the rear holes on the plate over the battery compartment. The seat assembly is only connected to the plate over the battery by two bolts now. Its a temporary fix for now, but at least I have the steering wheel out of my gut. I think in the future Im going to drill new holes in the spring steel assembly so I can bolt it in more then just two places.
I know my post reads like gibberish, so I will try to get some photos up. |
You're going to have a hard time drilling through the springs...I'd drill holes in the mounting plate instead.
![]() Quote:
Haha I would LOVE a Cub Cadet Super Garden Tractor! I was thinking of making a plate just like that, or just getting some lengths of straight iron and putting a length on each side then mounting it all together after drilling holes in the straight iron. Thanks for the advice so far guys. |
![]() Quote:
