Old 07-16-2013, 06:18 PM
Nightow1 Nightow1 is offline
Default Tie Rod?
I have a Model 70 I'm rebuilding from ground up as a pulling tractor. I wanted to know what other models have the same Tie rod, and if there is anything i should know as far as upgrading for pulling. All opinions are welcome
Thanks in advance.
Old 07-16-2013, 06:33 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
all the narrow frames use the same one. just make sure you have good rod ends on it. I've seen more tie rod end failures at pulls than you could imagine
Old 07-16-2013, 06:45 PM
Thank you for the quick reply, I found a good set on E-Bay for $20.00 shipped. they look to be in excellent condition.
Old 07-16-2013, 06:49 PM
Get this style from here. They are way better than original. Scroll down, should be part #60645K431 without a grease fitting. With grease fitting is just below it.
