Old 07-30-2013, 07:48 PM
Randy Schrecengost Randy Schrecengost is offline
Angry Cub Cadet 2072
Hello Randy here I have a cub cadet 2072 super cub. I need information on how to replace seals and O rings in control valve on the power steering. It is pushing oil up out of the steering colum. THANKS I have had lots of International Cub Cadets but never had to deal with power steering on International,
Old 07-30-2013, 08:02 PM
ken6x6's Avatar
ken6x6 ken6x6 is offline
First off welcome to OCC!
second, very common issue. repairing those pumps is pretty darn close to surgery if you ask me. it can be done, but your going to need the repair book and lots of patience. i had a 6 week night mare with mine. i took it to a professional hydraulic repair shop and at the end they gave me back a pump with new seals that didn't work. i actually had to buy a second pump and take it apart to figure out what they screwed up. wound up being they put the little check ball back in the wrong hole. after that it worked perfectly with no leaks.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 07-30-2013, 08:08 PM
Darrell Darrell is offline
I am not sure about this being the same column as a Cub , but i am thinking i saved this because someone said a Cub is the same. Hopefully someone will come along and verify if a Cub power steering is the same. Don't tear your column apart until someone verifies this .
I would also locate and buy a SERVICE MANUAL for your tractor. It has pics and info on doing this.
http://www.mytractorforum.com/showthread.php?t=208848
Old 07-30-2013, 08:17 PM
ken6x6's Avatar
^^^ that's the one. its made by Parker. the seal kits are cheaper from JD then cub.
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 07-30-2013, 09:03 PM
Taking these apart is pretty complicated. If you're good at taking something apart, well organized, and you are familiar with hydraulics.... you should still think twice. They can be tough. If your not mechanical, DON'T DO IT!!
Welcome to OCC!!!
Old 07-30-2013, 10:03 PM
Old 07-30-2013, 11:17 PM
Leadslingingdaddy's Avatar
Go on weekend freedom machine site and search for 318 steering rebuild....Same pump...it will take you to a very good link with detailed instructions on how to do it...I did it in about 3 hrs....Very tedious but doable...
Old 07-30-2013, 11:27 PM
There you go...
Old 07-31-2013, 11:52 AM
Welcome to OCC! Good luck on your steering rebuild. I also need mine rebuilt on my 1872.
Old 07-31-2013, 07:06 PM
cub123's Avatar
cub123 cub123 is offline
The MTF thread is a good thing to look over before digging in. Clocking the metering plate and getting those springs in is the biggest issue. CARFULLY set a rag over each spring after its in, that way if it pops out while putting in the others you won't have to spend 20 minutes looking for it on the other side of your shop
