Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 08-07-2013, 01:30 PM
V30crewcab V30crewcab is offline
Default Changing alternator belt on 1782?
will the driveshaft unbolt and slide back enough to change the alt belt, or does the engine need to come out? all the way out on the adjustment and looking rough! already have the radiator out currently.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-07-2013, 05:28 PM
You can pull the drive shaft by removing the 4 bolts that attach it to the adapter at the rear and then slide it out of the front CV joint.
Old 08-07-2013, 06:21 PM
sweet, thanks.
72 scout
IH 404 tractor
Old 08-07-2013, 09:08 PM
I would pull the cv's apart, clean and re-grease them also.
Old 08-07-2013, 09:23 PM
is there a special grease I need to use on the cv's? was thinking of doing that while it was apart.
72 scout
IH 404 tractor
