Old 08-31-2014, 04:47 PM
rbigg rbigg is offline
Default Kawasaki FD-620D question
Well, I see I've stepped in it now.....
I have a Cub Cadet 3205. The engine is a Kawasaki FD-620D. That's all to the good. Then we come to what model of FD-620D it is.
I have one reference saying it is an FD-620D / S21. So far, I can't find anything on models. Is FD-620D / S21 a good model for my 3205?
If this isn't correct, I need to know where to find the model no of which FD-620D it is......
I'm trying to buy front and rear crankshaft oil seals, and the model of FD-620D is important.
Old 08-31-2014, 06:49 PM
According to the Cub Cadet Chart, the 3205 came with a Kawasaki FD620D with spec number AS21
I went to: CC Parts Look up
I found Oil seals.... KM-92049-2112
Old 08-31-2014, 09:18 PM
I don't know much about engines. But, I want to know if the following is right. This is sort of nit-picky:
This Kawasaki chart does not list AS21:
http://kmcb2c.econnect.partsandwarra...MBEROFITEMS=63
Hopefully, the designation S21 agrees with Kawasaki's chart.
I hope the front and rear crank oil seals are not in the variations of the engine. I would hope they would be the same. Same thing for pan gaskets. Hopefully they are not different from variations of the engine.
Old 09-01-2014, 05:49 AM
The information that was supplied earlier is correct and accurate. If you don't believe it, then do an internet search and see what you can find.
Old 09-01-2014, 08:13 AM
My 1999 built 3205 has a FD620D-BS21 in it. Roland has the correct seal. Looks like the front and rear are the same.
http://www.jackssmallengines.com/Jac...saki/18063/354
Old 09-01-2014, 10:29 AM
Parts tree also says the same thing. KM-92049-2112
Old 10-06-2016, 07:04 PM
Byronmill Byronmill is offline
Did the Cub Cadet that used the Kawasaki fd620d engine have the nylon gear or the steel gear on the cam? My brother-in-law has a 3205 that is having some problems running. It popped a push rod out of place, but did not bend it. Still not running right after put back in place. Wonder it might be the same problem in the John Deere's with the fd620d and the plastic cam gear failing.
Old 10-07-2016, 08:38 PM
spudder spudder is offline
The early FD620D engines had the plastic timing gear. As I understand it, somewhere in the 1998 timeline, Kawasaki started using steel gears.
It is common that the earlier engines with 500-750 hours had the gear fail.
They are good durable engines if they have the steel timing gear upgrade.
I bought a 1864, it's just grown from there. The Cubs have replaced old Chevys as my hobby/passion. The only car I have left is a '67 Chevelle wagon.
Seems like a good trade off. I can put five Cubs where one car sat and there are no titles or license to fool with!
Old 10-14-2016, 05:38 AM
jsoluna's Avatar
jsoluna jsoluna is offline
My 99 3205 has steel gears. They are fantastic engines.
