Old 10-04-2013, 04:21 PM
Dave R Dave R is offline
Default Removing old Decals
What is the preferred method to get the old decals off the hood of my 149?
I have tried several concoctions but none seemed too successful. What would happen if I rubbed a little acetone on them? I have seen it take paint off real quick?
Sorry I jumped too quick, I think I found my answer in the "Search" feature here. Found it after I posted this, now I don't know how to delete it in its entirely.
Dave
Old 10-04-2013, 04:28 PM
OldAndInTheWay's Avatar
I just remove a set using my heat gun... A commercial strength one.
They peeled right off. The leftover glue is harder.. Acetone took care of it.
Old 10-04-2013, 04:30 PM
I just remove a set using my heat gun... A commercial strength hair drier.
Ditto on all counts....
Old 10-04-2013, 05:41 PM
CubyFan CubyFan is offline
Default Heat Gun
I use a harbor freight heat gun I picked up on sale for $9.99. Takes the sticker off in a few seconds and you can remove the residual glue with acetone. With a little care there will be no damage to the paint.
Cheers, Rick
Old 10-04-2013, 08:06 PM
Heat gun and gasoline on the glue works for me
Old 10-04-2013, 08:41 PM
Did anyone besides me ever use a heat gun??
If you get good at it, the glue will mostly come off with a putty knife while still warm.
I keep a new plastic putty knife that I got at Sears just for removing decals.
Keeping the paint intact (no gouges) is easier than trying to restore partially scraped paint.
Old 10-04-2013, 08:49 PM
ksanders ksanders is offline
I too use a harbor freight heat gun with awesome results. Have for 10 years. $10 pays for itself first time with all the time you save peeling and/or repainting.
I've also used a sharp razor blade scraper with success when paint doesn't matter but wear gloves and BE CAREFUL as they can slip.
Preserving history... one Cub at a time.
Old 10-09-2013, 08:23 AM
fpatd's Avatar
fpatd fpatd is offline
I also use a heat gun , & then some solvent ,
I guess there is no smoking around Sam's place !
Old 10-09-2013, 09:03 AM
A plane old hair drier set on hi also works,
