Old 10-10-2013, 03:12 PM
OldAndInTheWay's Avatar
Default This just popped up for sale.
Says it need a starter/generator. How could one tell if it ran?
Also says it's a 1960 model. Wouldn't that be 61?
Old 10-10-2013, 04:25 PM
The Original was built between Ocr '60 to Aug '63.
Old 10-10-2013, 04:40 PM
Maple Cabin's Avatar
Maple Cabin Maple Cabin is offline
Take S/G with you when you go to look (pull a good one from one of your running cubs)... Ask if you can mount it to test. If he won't then there is more to the story.
Doug
126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights
129 Deck, Blade, Weights
1200 Creeper Deck: 1250 B Tiller odd deck
782R with power steering
JD 110H:JD 112H
Old 10-10-2013, 04:41 PM
I would ask them how they determined the model year.
If you're interested in it, find out what "needs a S/G means". Could be that it doesn't/won't charge but will start the engine.
If they aren't asking very much for it, then (I think) it's ok to buy a "pig in a poke" if they are asking a higher price then I won't buy it without hearing it run.
Worst case, take a hot battery/battery pack, some gasoline in a squirt type oil can, and a known good S/G with you when you go to look at it. You can't very well buy a tractor without hearing it run...
Asking $525
I haven't seen an original for sale around here before. It looks really nice and original. I wonder if it has been restored in the past? I can get the starter/generator rebuilt locally.
I like it with the fenders.
Old 10-10-2013, 05:03 PM
cubby102's Avatar
cubby102 cubby102 is offline
Its a good possibility that its a early one I'm not seeing a creeper hole. Imho I would take the chance but I have a soft spot for originals
Old 10-10-2013, 05:04 PM
I looks clean... deck and tires look good too. This this has spent a lot of time in doors. If it's had a resto it was a long time ago. Worst cass rebuild engine and S/G $$ if fits your budget.
Ask if he has had any tractors between the two in the picture. If no, good bet it good to go.
Good luck
Doug
JD 110H:JD 112H
Old 10-10-2013, 06:40 PM
Didn't real early ones have no drain hole in seat? Maybe seat got trplaced you never know. But also mention of it being early with missing frame cutout? Hope the O masters will chime in. I like it
Old 10-10-2013, 08:49 PM
Owner has owned it for 30 years.
Going to check it out on Sat. If OK it will be coming home with me.
Old 10-10-2013, 09:09 PM
garnold's Avatar
garnold garnold is offline
Good luck man and hoping to hear a happy ending to this story
