I am trying to decide if installing an oil cooler to Kohler engine would be beneficial or a waste of time. I have an 1863 that gets extremely hot more so than the Kohler 20 HP I had in Sears tractor, and I worry it will toast it. I read stories of people have heat issues with 2500 series as well, and I am soliciting opinions as heat issues are new to me. Thanks for the help.
Second, maybe your motor is running lean, and causing extra heat. Have you pulled the shrouds and cleaned the engine? Maybe it's just plugged up. |
Kohler sells them. You replace oil filter with a plate which has 2 hoses going to cooling radiator. The radiator then fits next to engine, and part of blower housing is cut away for the blower air to blow over it. Filter is reattached to the plate. See Kohler oil cooler 54-755 21-s on internet for a picture of it. I was thinking it was running lean as well. I also think it has a blown head gasket. I am also concerned there is so little area around engine for air flow. Is this typical with that style tractor.
I fit a Kohler oil cooler to my 1863. The cooler fits on the left side of the engine fan shroud. There is an adaptor which fits between the engine and oil filter with hoses to/from the small cooler. Sourced from fle-bay. Seems to work fine and fits under the plastic panels. I also use an oversize oil filter. How much does it help, don't know. But, it makes me feel better. I run 10W-30 Mobil 1.
http://www.ebay.com/itm/24-755-120-S...-/190734632684 Looks like a pretty complete kit to me.
Cubfan,
Did your oil cooler come attached to the side? This would be much easier to put on that way. I wonder if it has helped with oil temperature. All the instruction manuals indicate the blower housing has to be cut about 3" X 3" and the blower blows over it. I think that is fine, but I hate cutting into blower shroud and would rather do it the way yours is. Would mounting it just outside of the engine be enough to lower oil temperature, and therefore, lower overall engine temperature? I also question the hood and side panels being so close to engine. The new cubs have much larger areas around engine for air flow, and the older ones had no side panels. |
