Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 07-03-2016, 10:20 PM
DieselDoctor's Avatar
Default D600 Water pump
Does anyone have a source for a 15852-73030 water pump for a D600 that is reasonably priced? The cheapest I have found is an after-market Kumar brand pump for around $100 on fleabay. Is this a reputable brand or should I stick with genuine Kubota parts that are north of $175 or more? I checked with the vendors that support this site and didn't see anything listed. Thanks in advance! Stan
Old 07-03-2016, 11:25 PM
This is OEM. $108.00
http://www.kubotapartsdealer.com/wat...p-15852-73030/
Up to 534 and counting...
Old 07-04-2016, 10:11 PM
Any thoughts on the Kumar brand? $108 for genuine Kubota isn't too bad.
Old 07-04-2016, 10:54 PM
I have no thoughts about the Kumar one,I would just buy the bota one,it's oem bota,looks and smells like a bota too.
Old 07-05-2016, 12:44 AM
The "Kumar" one is likely just from Kumar Bros, a high volume Kubota dealer.
http://www.kumarbrosusa.com/kubota/kubota-parts.html
http://stores.ebay.com/Kumar-BrosUSA
Old 07-05-2016, 10:24 AM
Thanks for the info guys. Looks like that will be the one.
Old 12-01-2016, 09:09 PM
WEL58's Avatar
WEL58 WEL58 is offline
I bought the Kumar D600 WP this summer. The bearing seized up in middle of cutting grass. Had the new WP in two days.
The casting looked a little rougher was than the original Kubota WP but heck bearings and seal should be OK. The Kumar pump has about 60 hours on it without any problems.
Last night press apart the original WP and found the pump seized because the weep hole was plugged and coolant got into the bearing.
Need to now source a new bearing and WP seal.
Bob G.
Old 12-02-2016, 07:55 AM
Usually the seal gives up first then coolant/water leaks ever so slowly corroding the hole shut over time.
Old case of which came first, the chicken or the egg.
(personally I think the rooster did)
Old 12-02-2016, 09:24 AM
Got one thru CARQUEST this fall
It was a Kumar brand also
Shoulda went w/Ebay for less!
Old 12-02-2016, 11:40 AM
Oak Oak is online now
Didn't Frank F3 rebuild his own?
