Old 12-29-2013, 08:34 PM
macman81's Avatar
macman81 macman81 is offline
Default My 1650 needs more electrical output!!
i have a 1650 that is full time cab/thrower duty. i am installing a small electrical heater to clear the windshield and take the chill out since at times I'm in it for an hour or more if we get a large snowfall.
the heater actually puts out pretty good heat but manual says it draws 12 amps on low and 20 amps on high. i don't think my 15 amp electrical system it up to the task... even with led headlights that draw pretty much nothing. I have an electric windshield wiper but only turn on for short periods of time. Also have an led strobe light which draws very little. and the electric pto I'm sure draws at least 3-5 amps. so even on the low setting I've pretty much maxed out my electrical system.
reason i started this thread is i need ideas on how to get more current without making the tractor look stupid lol. i am considering a very small alternator of some sore off the back of the hydro shaft? or how hard would it be to get another stator mounted elsewhere on the machine and just run two stock charging systems? I have another stator flywheel and regulator just not sure where it could fit?
any ideas would be appreciated.
I figure i should have about 30 amps total to do this right.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 12-29-2013, 08:42 PM
You could install a 30A stator that Kohler makes. But then, you would have to get a 30A V/R and upgrade your wiring to 10 Ga Wire, to handle all the extra amperage. Hmmmmm, would it be worth it...????
Old 12-29-2013, 09:01 PM
macman81's Avatar
So most kohler stators mount the same/use same magnets? maybe this 25 amp command conversion kit would work? price is right and would look pretty stock other than regulator looks different and of course wiring needs to be beefed up.
what do you think Roland?
http://www.ebay.com/itm/KOHLER-COMMA...item4acce639c3
John,
PROUD OWNER
Old 12-29-2013, 09:22 PM
sawdustdad's Avatar
propane heater? Li'l Buddy? You get enough air leakage that CO would not be a concern. Or, get one of those heaters they make for trucks and fab a hot water circuit by wrapping the muffler with a copper coil and put a small electric pump on the circuit. The Li'l Buddy heaters work pretty well, just need to find a place to put it.
Old 12-29-2013, 09:58 PM
bluesman bluesman is offline
Question
Doesn't your cab trap some engine heat? I wondered about that because I have a chance to pick up a cab for my 1650
I will attempt to address my procrastination problem while you wait.
Old 12-29-2013, 10:14 PM
fourinchdragslicks fourinchdragslicks is offline
the cab would pretty much only trap body heat. engine and exhaust heat is directed out the front of the tractor
Old 12-29-2013, 10:22 PM
Could you run another battery off the back of the cub in a custom battery box for the heater and run it in parallel to your current battery? I'm not good at all with electrical, but that was just a thought.
Old 12-29-2013, 10:23 PM
macman81's Avatar
my main problem is the windshield will frost up if its really cold out. If the sun is out it is not normally a problem but i do most of my snow removal at night after work. I think i can squeek by with this heater on low heat which is 12 amps but still taxing the electrical system. did a test of this heater and it actually seems to move a lot of air and its pretty warm too.
John,
PROUD OWNER
Old 12-29-2013, 10:41 PM
The main culprit in fogged up windows is the breathing process. Air circulation in the cab would help.
Old 12-29-2013, 11:34 PM
macman81's Avatar
i was waiting for someone to suggest a fan! I just figure i put a cab on to get out of the wind i don't want cold air blowing around via fan lol. would like to circulate warm air instead of cold.
John,
PROUD OWNER
