Who makes there own battery cables? If so what wire do you use? #10 or is it #8. 10 looks thin. I was even thinking going to #6.
I use #2 gage and I solder the ends on.
1966__122 Cub Cadet. Owner: Calvin, 6 yrs old Dad: Craig |
#2 wow that's heavy.I guess heavier is better. What solder do you use?
Here is a link for welding cable. http://www.wireandcabletogo.com/Weld...FcEDOgodNWkAUw
For Electrical use, always use Flux core solder. Acid core solder (for plumbing)will corrode. For cable, you can NEVER go too big!! Greg
"If I can't fix it, I can screw it up so bad no one else can either" |
60%tin/40%lead .06 diameter
Thanks. I'll see if i can find cable and ends
Here is a link for cable ends.
http://www.wiringproducts.com/copper...FYw7OgoduxAAFg You can find them at Lowes or TSC you should also be able to get cable at TSC I put the end in the vise open end facing up, heat it with a propane torch, melt the solder in it till it full then slip the cable into the molten solder. I continue heating it till the solder has soaked into the cable. Cool it off, clean it up slip the heat shrink tube over it and heat that with a heat gun.
Do you guys still use #2 gauge to the starter also. I want to run new cables on my 149.
