After getting the 102 refurbished and painted I wanted to do something about the hood opening down on the grille. So first I moved the voltage regulator down on a rubber mount. Then I drilled and tapped a 1/4" hole in the top of the grille casting to bolt a small hook to. The next piece is mounted to a lengthened rear hood ornament bolt. The hood piece has a small hook on the end to catch the smaller hooked piece. No more marring the grille paint and denting the hood .
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake |
Nice job!
Yeah, that's nice. I'm surprized IH never did anything about that.
Nice work and a great idea!
Nice work. I'll have to make one of those when I repaint my 100.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Nice work!
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
What they said
Great idea!
