Old 02-06-2014, 08:28 PM
MinnesotaCadet's Avatar
Default New K321 block or not?
The K321 in my 1450 has a noticeable oval in the cylinder and I wanted to just buy a new block off Ebay. But would it be cheaper to buy a block or get the existing block bored over?
Connor
Old 02-06-2014, 08:44 PM
cubby102's Avatar
cubby102 cubby102 is offline
Depends on if yours can be bored to the right size. Have a shop mic it and see if you can get a piston to fit what would be needed
Old 02-06-2014, 10:44 PM
austin8214's Avatar
You can get over size pistons. My local machine shop will bore and hone a block for $60.
Old 02-07-2014, 12:21 AM
Depends on your ability. Always cheaper to rebuild yourself, than to buy new. Just depends on if you want the liability, or someone else to carry it.
Old 02-08-2014, 02:37 PM
I don't have any tools to bore out a block. I'll have to get to it this spring. My 1250 will have to take over work duties. She was my old work tractor anyways. I'll get back to you guys this spring when it's not under a tarp and -9 degrees out.
Connor
