Do you guys run the hytrans fluid you can get at tractor supply, or do you go to the dealer? I run the stuff from TSC in my big 404 tractor, and was thinking of using it in the 1782 as well. its a real long drive to the IH dealer vs 4 miles to tsc. the p/s cylinder is leaking a little when I turn all the way one way, so its gotten a little low.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
Well I have been running a hytran equivalent oil in my tractors for over 20yrs and have yet to see any ill effects to date. Go for it.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
i only run genuine HyTran. i don't have a cub or IH dealer with in 40 miles from me. i just order it online and it shows up at my door. it works out being cheaper that way. for me at least.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
cool, thanks.
Running TSC hytran in the 882 for about 3 years now. Seems to operate just fine, and I'll be interested to see what it looks like inside on my next fluid change.
Personally I use ONLY Hy-Tran.
Your tractor, your dime, your choice
I have TSC in my 123 and I use the tractor alot all year. It's been in there for 2.5 years and so far it's been fine. I'm going to change it in the spring and see how it's been holding up.
Only Hy-Tran for me, I buy it in bulk @ 5.00$ a qt. The way I look at it, Hy-Tran has been used in my 149 for 40 yrs. So why take a chance on using something else. I also use only the CC hydro filter.
Don B, USAF 1962-1968, Ft. Wayne, IN |
I use only hytran myself but if you are going to use the TSC stuff don't use hydraulic oil use tractor fluid there is a difference. Traveler is hyd oil and extreme tractor fluid is tractor fluid. Tractor fluid has more friction modifiers than hydraulic oil thus it will make your transmission last longer.
I've used HyTran, but have also used Shields universal tractor hydraulic fluid--says it meets HyTran specs. about $45/ 5gal pail.
