Old 03-09-2014, 11:14 PM
rigid rigid is offline
Default K321A carb question
Long story short : My 12 year old can't afford full size tractors so he is the proud owner of 3 riders purchased with money he has earned . Here is now where I come in . He kept telling me about this mower he found in an old barn where is buddy just moved . After brushing it off for several weeks we went and looked . turned out is is a 149 (72') and fairly straight . He bought it for $100.00 . We now have a good portion of it apart because it has been sitting 30 yrs .
I am trying to find a carb kit and parts tree said they had no parts if I did it correctly . Can anyone point us in the right direction or have suggestions on what to look for for this carburator .
engine K321A
spec no 60166A
serial # 4000184
Also somewhere we have come up with with that we believe it is a # 30 carb ?
As you can tell we are new at this and appeciate all the help we can get .
Thank you
Old 03-10-2014, 12:31 AM
Well, your not real new.... but
Partstree shows the kit...... Here. Scroll down to the bottom of the parts listing. Part # KH-25-757-01. You'll also see the needle and seat kit and others. The part number I listed should have the needle and seat in it, I was just pointing out the other kits. You can also get kits at NAPA, and O'Reilly's. If you need the kit number for the O'Reilly one, I have it.
Old 03-10-2014, 09:01 AM
For positive size ID.................
Look in the air cleaner side of the carb.
You will find either a "30" or a "26" cast into the upper inside.
Or, measure the I.D. of the outlet side.
Will be either 26mm or 30mm
Old 03-10-2014, 02:18 PM
Welcome to OCC!
Old 03-18-2014, 08:16 AM
J mech ,
If you have the o'reilly number I will try there first . We have on here in town . I did find the "30" inside . Thank you all for your help . I may wear out my welcome as we go through this project !!
Old 03-18-2014, 09:45 AM
Kit part number at O'Reilly's: Prime Line 7-02024
Old 03-18-2014, 10:22 PM
Thank you very much !!
