Maybe this issue has been addressed at somepoint, but I haven't been able to find it through searching. I have a 48" deck on my 149 that is in need of some TLC; however, it still mows ok. The problem I have noticed is after setting the height adjustment the front of the deck is nosed down. When the deck is fully raised the nose roller is only 1/2" off the ground
Are the front hangers adjusted to low and causing this, or am I missing some other adjustment here???? I have seen other pictures on here and the decks appear to be setting level when fully raised. Thanks!!!!!!
Make sure the pivot arm (upper left one with the u-slot in the end of it) is straddling the lift handle cross shaft.
here is a manual for it,shows how to check for levelness
http://service.mtdproducts.com/Train...n/IH-GSS-1464/
After looking this over I do believe the support clevis's on the front are the culprit here! Thanks a ton guys!!!! much appreciated!
I have noticed that on most decks I have seen on here there is an ID tag on the one end... unfortunately mine is gone...is there a reference available to determine what deck I actually have???
YUP... Show us pictures.
.....and measure it.
