Old 03-13-2010, 07:25 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Question oil bath air filter
Can someome exsplain to me how an oil bath air filter works. Dose the air go threw the oil then to the carb.? Any info. would be great or a diagram. Thanks
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 03-13-2010, 08:24 PM
young enthusiest's Avatar
I am by no means an expert, but I beleive sn oil bath sir cleaner works something like this: the air comes in the top of the aircleaner assy, and is spun around by fins that direct it to do so. The air travels down, and the tube it travels down, ends a very small distance from the oil in the bottom. The air must go under the bottom of the tube at very high speed, and that combined with the centrifical force of the spinning, forces all the contaminents into the oil, while the clean air travels back up to the carburetor/intake manifold. The only oil air filter I have ever seen is on a IH B-414 we had a couple years ago. I am pretty sure that is how it works
Old 03-13-2010, 11:39 PM
I think it's a bit simpler than that. The air goes down into the filter and then has to reverse direction around a sharp bend to go up into the carb. Thanks to Newton's 1st law, the dirt in the air wants to keep going down, right into the oil.
Old 03-14-2010, 12:27 AM
Matt is much better with words than I am. I tried to say what he said. But he made more sense
Old 03-14-2010, 07:15 AM
Amigatec's Avatar
Amigatec Amigatec is offline
They are also only about 80% efficient compared to paper which about 95% efficient.
Pat Benner Haskell OK
Old 03-14-2010, 01:28 PM
jeff k.'s Avatar
Thank you for the great info. I understand better now.
