hi guys i need to remove my front pto but can't get it too budge what is the tricks to make it come off
thanks thad |
There are two set screws in each hole. Have you taken all of them out?
I don't use my Cub. I just work on it and look at it. So far it's holding up very well. |
Mine had 3 short and 3 long, 1/8 allen head set screws holding it on. Are all yours removed?
![]() If the arm is still on, pull it back and rotate the pto until the U shaped cutouts line up. If it's off or disconnected, light taps with a hammer on the button will allow you to rotate it until they line up. Make sure the holes and the hex are as clean as you can get them. Use a high quality 1/8" hex wrench to loosen the set screws. There should be TWO in each hole for a total of six. After they are all removed, then you should be able to get it off. |
