Old 10-14-2014, 10:26 PM
lawman lawman is offline
Default Crank and rod
I need to know if the rod and crank is the same or different in a 10 hp. and a 12 hp
thanks in advance
Lawman
Old 10-14-2014, 10:59 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
different......
Old 10-15-2014, 09:18 AM
ford4150's Avatar
ford4150 ford4150 is offline
From another website:
To identify the 10, 12, 14 and 16hp Kohler crankshafts, the 10hp cranks have a shorter stroke than the other cranks. You can compare a 10hp crank to a 12, 14 or 16hp crank by placing them side by side, and with the counter weights down, looking at the bottom part of the rod journal, the journal on the 10hp will be closer to the main journals. (3/8" of difference in stroke.)
Old 10-15-2014, 02:14 PM
thanks for the info, I have I have a 12 hp motor that needs redone and I have two 10 hp motors that I don't know what shape they are in, I guess I will have the crank redone and get a new rod.
Old 10-15-2014, 03:37 PM
No need to pull info from "another site". You have all you need here.
All this info is in the Kohler K series service manual. You can download it here if you don't have a copy.
