Old 10-20-2014, 09:22 PM
highimpact highimpact is offline
Default Hillbillie from Kentucky! Cub 1810 needing info.
I have a #1 tiller an gear box. An need to know what all I need to mount it on my 1810? The tractor is stock only has a ball hitch. Any help greatly appreciated!
Old 10-20-2014, 09:43 PM
It WON'T mount. The #1 Tiller was intended for IH bulit Cub Cadets with a Cast Iron rear end.
Old 10-20-2014, 10:39 PM
Welcome to OCC.
Old 10-20-2014, 11:07 PM
Dang!! Wat tiller do I need to find? I only need small garden plots! I've owned several cubs but only used them to mow. Want to use this one to work a small garden.
Old 10-21-2014, 12:13 AM
I'm thinking of using a self-powered tiller-around here ATV-type tillers are more common.
Old 10-21-2014, 06:37 AM
The 190-400 was intended for your tractor.
Old 10-21-2014, 07:41 AM
That will probably be the way I have to go. Thanks
Old 10-21-2014, 12:24 PM
highimpact,
You had two threads asking the same question, so I merged them together into this one.
Everyone is correct, a belt drive won't bolt right up and work.
But....
FWIW, you can put a belt driven tiller on this machine, but you have to make an adapter. I did it.
Here is the link.
http://www.onlycubcadets.net/forum/s...ht=tiller+1811
The tiller is off the tractor now and put away for the season, so if you need any pics the back of the tractor now has a clear view. Just holler and I'll post some more pics.
Old 10-22-2014, 03:10 PM
Shoot yea John! Post sm pics with it off!! Really appreciate it!
