Old 12-20-2014, 03:08 PM
gdheck's Avatar
gdheck gdheck is offline
Default Using Napa replacement Kohler parts?
Anyone on here have anything they can tell me about Napa replacement parts for a K-301? I normally only use genuine Kohler parts, but I have been thinking about trying Napa's line of parts. I'm interested in a piston and rings, rod and valves. I've always wondered if they would be inferior to genuine Kohler, but I can get them for about 1/2 the price of Kohler parts.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 12-20-2014, 03:30 PM
I'm about to start on my 3rd engine rebuild using NAPA Stuff.
Its a 12 HP from the 126. Matter of fact, they just called this AM and said it was ready to pick up
The other 2 were a 12 and a 14 from my QL's.
So far so good.
Old 12-20-2014, 04:49 PM
Merk Merk is offline
I've been using NAPA parts for several years with no problems. My 100 has a rebuild engine kit from NAPA in it. Anyone at a plow day knows I will pull RPMs down from 3800 rpm to 2800-2900 rpm and run that way all day long.
Project Uncle Dick
Cub Cadet 70
Old 12-20-2014, 06:57 PM
I buy so many parts there that my NAPA dealer has started giving me a small engine parts book when each updated book comes out.
Old 12-20-2014, 07:07 PM
Last set of head gaskets I bought for a Mag18 from NAPA were Kohler parts and about 1/2 the price of the local "authorized" Kohler dealers.
Old 12-20-2014, 07:21 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
My local NAPA offers both genuine Kohler parts and private label NAPA Small Engine Parts. I've never had a failure with either brand.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 12-20-2014, 07:35 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
I don't want to get shot here, This might even need to get moved to Custom Cadets.. But while we are talking about Napa!! Is there Napa list parts for other things also? The filters and parts, or what not.. hydro filters, air filters..
I am broke, but I make it work!
Old 12-21-2014, 01:34 AM
darryljs's Avatar
darryljs darryljs is offline
Here's a list of some stuff I found from NAPA. I think there may be more things. Hope you find this useful.
Cross Reference Cub Cadet to NAPA
Tie rod end CCC # 723-3018 NAPA # 7-04231
3/4" wheel bearing IH # 394883R93, NAPA # 7-04292
1" wheel bearing CCC # 741-3002, NAPA # 7-08412
Electronic Voltage Regulator plug NAPA # 7-016008
5 prong ignition switch plug NAPA # 7-016034
Breaker points Kohler # 47-150-03, NAPA # 7-01029
Condenser IH # 62188C1, Kohler # 230722-S, NAPA # 7-01338
Muffler, models 102-149 IH # 393840R91, NAPA # 7-03680
Hydro filter CCC # 723-3014, NAPA # 1084
Hydro filter for auto gear pump CCC # 723-3014, NAPA # 1410
Rear wheel seal CCC # 721-0187, NAPA # 9878
Hydro input seal IH # 394847R91, Sundstrand # 9008000-6201 NAPA # 6204
Hydro trunion seal SN 592014 & below IH # 383534R91 NAPA # 6720
Hydro trunion seal SN 592015 & above Sundstrand # 9008000-6701 NAPA # 6763
PTO bearing, models 70-169 IH # 60071C91 NAPA # RA100RR and PRA100RR (cheaper version)
Engine oil filter Kohler 52-050-02-S, NAPA # 1348
Engine oil filter Kohler 12-050-01-S, NAPA # 1056
Shaft seal for Narrow Frame Hydraulic lift pump IH # 347478R91, NAPA # 4911
Sway bar repair kit to replace Quiet Line ISO mount rubbers NAPA # 265-1285
Spark Plug Cross Reference Chart
Engine – Kohler K241 (10 HP), K301 (12 HP), K321 (14 HP), K341 (16 HP)
Manufacturer and Number ------- Mfgr. Stock Number
Champion H10C --------------------- 844
Denso W14L --------- -------------- 6013
NGK B4L ---------------------------- 3112
14mm, 7/16 reach, 13/16 hex. These plugs recommended for stock engines.
Engine* – Kohler K241 (10 HP), K301 (12 HP), K321 (14 HP), K341 (16 HP)
Champion H8C ------------------------ 587
*These are colder heat range plugs for use in modified engines with higher than stock compression ratios.
Engine – Kohler K141 (6.25 HP), K161 (7 HP), K181 (8 HP)
Champion J8C ------------------------- 841
14mm, 3/8 reach, 13/16 hex.
Engine – Kohler KT17 Opposed Twin
Champion RV17YC --------------------- 25
14mm, .460 reach, 5/8 hex.
Engine – Onan 20 HP Opposed Twin
Champion RC14YC --------------------- 431
14mm, 3/4 reach, 5/8 hex.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 12-21-2014, 01:57 AM
bocephus1991's Avatar
I've used napa coils and points an condensers with no problem. I didn't see it listed but the air filter is #2296 gold series $20 fits the k- series. Tried the one from tsc and its to small.
Brian
Old 12-21-2014, 03:16 AM
TheSaturnV's Avatar
darryljs,
Outstanding list.
Take these numbers and head to Tulsa Engine Warehouse:
http://tewarehouse.com/Catalog
Plug any part number you can into the search. Great folks and some of the cheapest prices I've found online.
As always, support your local businesses or the sponsors here if price + shipping is close.
