Old 12-18-2014, 10:30 PM
SJones SJones is offline
Default Fuel leak
I have a 126 from built in 1971. I just recently started finding fuel in the filter. Nothing dripping from the filter housing, but the bottom of the filter is saturated and heavy. It does start a little rough from the high vapor to air mix but runs fine once warmed up. Before I take it apart, any suggestions on where I should concentrate my search for the issue?
Old 12-18-2014, 11:01 PM
its probably the needle/seat or the float is sticking.
Old 12-18-2014, 11:19 PM
If you mean that the air filter is wet then as olds56612 suggests the float is sticking/bad/out of adjustment, OR the needle and seat are bad or have crud in them.
Rebuilding these carburetors sounds intimidating, but they really are pretty easy.
Old 12-25-2014, 09:46 PM
Ok I will look closely at those first. Thank you.
Old 12-25-2014, 10:31 PM
bocephus1991's Avatar
Don't my let the carburetor intimidate you there pretty straight foreward and simple. I've rebuilt my 2 had the apart and cleaned them up too , think I could do it blindfolded now!
Brian
