Found this on CL. Will these fit in a D600 or D640 engine mount? I know there is a lot of other stuff that would have to be fabricated too. I'm thinking he is also a little high on the price. He says there was 930 hours on the meter but I don't like buying something that I haven't seen run from someone I don't know. What's it worth or should I let it go?
![]() http://atlanta.craigslist.org/eat/grd/4855341592.html
Todd,
I don't have one here to look at, but Tim (Spudder) and I looked at the larger Kubota's before and we just don't think you can squeeze them in. They are a few inches longer. The D640's just barely fit as is. You might be able to, but no way will it have a front PTO. FWIW, I have a 3cyl Mitsubishi diesel from a Jacobson, and I've looked at it every which way I can and just don't think there's room. Plus, you have to remember it's a larger engine and really needs a bigger radiator. I think the Kubota's cooling system was pushing it anyway. Price wise, it doesn't look too bad being it appears to have a lot of parts on it. I know what you mean about buying something you can't see run from someone you don't know. Don't know what to tell you..... If you can steal it... say $500, it would be worth getting and seeing what you can do with it. You have some "other" brand stuff IIRC, surely you could do something with it.... ![]() |
![]() Quote:
http://www.onlycubcadets.net/forum/s...ad.php?t=22511
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
I dunno Ben. Like I said, I don't have one here. Looks like his fit! Maybe it was the D900 (? I think that's right) that we were looking at. What was the Kubota machine is was in???? ........ It was a front mount 4X4 Kubota mower. 2XXX or 3XXX. Can't remember, but we didn't think it would fit. I know my Mitzy won't. Oh well... Like I said, I'll surrender to that thread. Looks good to me!
Pretty sure it will go looks like it's maybe 1/4 longer at most. I have a PDF on it and I'll e-mail it to you.
![]() Quote:
![]() Todd, like Jonathan said, the price isn't bad, but less would be better.
I need to repower a 982 so I would need to flip the cooling to the front side and fab a bunch of stuff for that. I don't know if the radiator he has will fit either. But I'm looking at $1300+ for an air cooled Vangaurd. I had a D722 in a Kubota G1900s and it was a beast.
Too bad it's 6 hours away from me.
Todd,
Pretty sure it's the same size as the D600's and D640's. Extra bore and stroke. ![]() Back on topic, I'd buy. Worse case scenario, if it doesn't work, you could easily sell it and make back your money and them some. Keep us posted. ![]()
Josh Diesel Cub Cadets........... |
http://www.standardcrankshaft.com/cr....html?sid=4699
I found this. Looks like the crankshaft is the same for all 3.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
