Old 02-08-2015, 09:36 PM
cub125 cub125 is offline
Default Need advice on next purchace
I currently have a cub 125 that I bought for my son that has been awesome, we have a great time pushing snow and just using it, we bought it for a restore project but my son doesn't want me to tear it apart now, so I have decided to buy another one to restore, and I would like to get a manual since we already have a hydro, locally I have found a 70, 71, and a 1200 which of these would be the best option, I have read about the clutch and isolator issues with the 1200 but i do like the fact it is 12hp.
Old 02-08-2015, 09:45 PM
Buy another 125 I have two now. I had a 122 and a 125 previously. The gear drive was loaded with options but I liked the 125 better.
I traded the 122 for a 125 with hydraulic lift and couldn't be happier
If you get the 1200, I make solid mounts that bolt in place.
Jeff
The best advice that I could give you, if your son likes cubs and it is going to be a father-son project to restore it, is to ask him on which one he wants. You might also look at what parts/extras are included with each. You can run up a bill if you are paying shipping on all kinds of parts that might be missing from any one of the models. The parts between the 70 and 71 model will interchange, so if you acquired both then you would be able to swap parts if needed. Some of the extras can get pricey, like lights/light switches, correct seat, spring assist, 3 point hitch, attachments, etc... Those can all be factors in the deal and I am sure that I missed several, so others can chime in and help you further.
Old 02-08-2015, 10:15 PM
yeeter yeeter is offline
Knowing that you are going to have the 125 apart in teh future, sticking with the same model does make parts easier (by another 125 to restore, plus a 125 parts machine that the two of you can rob as needed).
Then you have a father/son matching set....
Old 02-08-2015, 10:25 PM
I thought about another 125, but older cubs just don't come around often here, there is a 129 that just posted, I know it's a wide frame, but how does it compare to our 125?
Old 02-08-2015, 10:42 PM
I'd go with the 70 or 71 especially if one of them has the round fenders. The 129 is a nice machine and the wide frames ride nice and are easy to work on since there's a little more room.
Old 02-08-2015, 10:52 PM
Neither the 70 or 71 have fenders, and the 71 does not run, and the owner doesn't know why.
Does the 129 have the same hydro as a 125?
Old 02-08-2015, 11:06 PM
Yes, as far as I know there no real difference.
Old 02-08-2015, 11:10 PM
Hydros and gear drives are two different animals, each with their own advantages and disadvantages.
Differences in HP and options make up huge differences in these tractors.
I think to get the best advice from the guys here, it would be best to tell everyone what kinds of things you want to do with the tractors.
However, all things considered, if you buy an old Cub Cadet (any model) and spend time working on it with your son, how can you loose?
When you get it finished, another one will come along in short order (they always do).
Yes, the transmissions and rear ends are the same 125 and 129.
Old 02-08-2015, 11:21 PM
Thanks, whatever I end up with will be used for some snow removal and pulling a aerator and cart. I have hopes of someday getting to attend a plow day, but I don't know if that will happen.
