Trying to install a bolt on plow on my 123 but the subframe is hitting the bottom of the axel.[ATTACH] .
Post pictures of the ears where it bolts to the front of the frame.
I cannot get my bolt on snow plo we to mount on my 123. It is hitting the bottom of the front axel.2015-02-21 14.09.47.jpg
2015-02-21 14.10.34.jpg |
Sorry for the double post I am doing this from my phone and it is the first time I have posted anything from my phone
You need a pair of bolt on brackets from the front blade to frame.
what are those brackets that are on the frame made for
Or the mule drive hanger without the pulleys and the undercarriage attached.
You need two of part #19, which are easy enough to make. Also you don't have to bolt it to the tractor, You can use a solid rod all the way through (#14) makes mounting/ removing a little quicker.
If you have a mule drive bracket this is what I did on my 100, no extra brackets to bolt on and off to switch between blade and deck. This is what darkminion was talking about also.
Collection: 100, 71, 128, 169, 582, 682, (2) 782. 1980 Scout Traveler Diesel. |
