I ran across this 1862 on CL, it was also on the Farm Equipment company's Webb site. "The tractor was a trade in, the owner passed away , It had been parked in a barn for years, They couldn't get it started" As is Where is $500.00. So I bought It. Hauled it home put a good battery in it (expecting to find it sized or knocking) it cranked and had good compression, but would not start. Took plugs out had spark, no gas to the carb, Somebody replaced the starter solenoid and fuel pump and crossed the lines, the out was connected to the crank case and the pulse was connected to the carb I changed the oil and filter (oil was like water) is started right up, all things seem to work (50" deck and mule not back on, They took off to move with fork lift)
It runs drives fine, its quiet. The transmission is low on fluid... What kind can I add for now. Until I can change it. The local TSC has "Cub Cadet® Drive System Fluid Plus" $14.99 QT Suggestions, Thanks |
First, welcome to OCC...
![]() Congratulations on your purchase. Quote:
See Hydraulic Fluids........ Hydraulic Fluid It is most economical if purchased by the Gallon at your local Case/IH dealer. The rear end takes 7 Qts.
Elway, welcome to the forum and congratulations on the 1862! I'm sure it will serve you well. This forum and the members on it, is a real treasure trove of information that can usually get you up and running with just about anything you run with your cub.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
I'm a newbie here too Elway.
Great knowledge and better, experience here that forum members will be more than willing to share. Please do keep us updated, I myself need to know. Heck, all want to know how you're makin' out!
Tankman '95 CCC 1641 Eastern PA USMC |
Welcome to the Cyclops club. Here are a few threads about what you now own.
http://www.onlycubcadets.net/forum/s...ad.php?t=33244 Holler if I can be of assistance.
Can some one tell, Who makes the hydro pump in this tractor? Can't see a tag. sn/816321. Thanks
1862's had Sundstrand hydros.
