I picked up an 1864 the other day that had a strange (to me) hood on it.
There was no Cub Cadet script on either side of the hood and no holes had ever been drilled to accommodate the scripts. Is this a service hood maybe? |
How about a pic Mike?
You're not going to get much info unless you post a pic
![]() Edit: Is it plastic? Metal? Shaped the same as standard cyclops hood?
-Ryan
I don't have a camera here. This shouldn't be too hard to imagine. Just no script. Never seen one like that before. |
So the circles would be where the red is in this pic? The way I'm imagining this is the 3 holes where the Cub Cadet script would be on the side of the hood aren't there, it's just solid all the way around.
If that's the case, that's normal. My 1864 hood has the holes since it has the script, but my 2284 doesn't have these holes as it has a decal on it. Hope this helps? ![]()
-Ryan
My 1641 hood is the same way as yours Mike. The script that was on mine was stuck on with double sided tape. Probably one of those Cub design changes. More than likely it was easier to produce a hood without mounting holes and an emblem without mounting pegs on them.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
Late production, they went to a stick on POS that looks like crap and falls off.
-Ryan
I guess that explains it. I've just never had one like this.
Yep that's the one. This is the labels list from the Cub parts site. Mike Now you do.
