I'm planning to go to my first plow day next weekend and I'm not sure how much weight I need. I currently have brand new Carlisle tru powers loaded with washer fluid and no wheel weights, will that be enough to get me by? I won't have the time or extra money this week to round up any weights so if I don't have enough I guess I'll just make different plans.
I use 3 sets of wheel weights and ags, no problem, see you next week.
What size are the loaded tires?
Tim I think you will be fine with the set up you have now. I have seen guys pulling plows with turf tires before. Hope to see you there next weekend.My 147 has 1 set of IH weights and Carlisle ags and it pulls a plow nice. Kelly
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
I think you'll be fine with that set up also. May grab 1 set of wheel weights and take just in case.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Doh! I didn't realize he had NO wheel weights. I though he meant he didn't have many, like as in more than one set.
You'll be fine. Loaded tires should be all you need. I've plowed on 6-12's with 75lbs of weight. So, loaded 8.50 should be equal. |
Use the moveable weight in the seat or over the left fender as seen in this one pic, this other show a kid plowing with turfs - it all works some better than others. My 122 has loaded Firestone AGs and a dual mostly hanging on the left side, it has way more traction than needed most of the time.
You'll be fine with the loaded AGs. Have fun! |
Thanks for the info. Now for my next question, the brinly plow I barrowed from my grandfather seems to be missing all the parts for the Coulter wheel and I'm not sure if that's a big deal?
