Good evening folks,
I am nearing the point in my 1200 QL rebuild where I need a new 3 pin driver. I have read several older post and it seems obvious that the stock driver is very flimsy. These things are selling for $120-$130 new and the used ones dont appear any better than mine. Before I bite the bullet & buy one, Is there anything I am missing that I can do or an alternative to make this any different? I think alot of you veteran members are very crafty when it comes to improvising. thank you Dave
![]() 1976 Cub Cadet 1200 & 44A mower 1964 Cub Cadet 100, No Attachments at this time, I do have a cart to pull stuff around. |
Post up pics of the driver. Maybe I can figure an inexpensive repair
Lakota has nice aluminum 3 pin stock replacement clutch drivers for $55.00.
Chris
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck As you slide down the banister of Life, may the splinters point in the right direction .
the 3 pin driver on a ql is designed to flex since its a rubber mounted engine, if you put solid mounts in you can run a standard non flex driver thats much stronger and cheaper.
I had considered going with solid mounts, but I've already got new rubber one's
I'll post a picture tomorrow Thanks Dave
Well.... then you better shell out the $130 for a new one.
It would be cheaper to buy a set of solid motor mounts off Jeff and a used regular 3pin driver. Your choice. |
Jeff |
Texas Blues was talking about trying to fix his here;
http://www.onlycubcadets.net/forum/s...054#post263054 Maybe he will chime in or you can PM him and see if he had any luck doing so. |
