So was able to nab this today. Has a bad engine, and as luck would have it I have the one out of my 2072 ready to drop in. Plastic is not real old according to Larry, but a nephew bumped something a snapped a mount. Lister plow and a homemade carryall are in the truck :-)
Congrats on the super
kinda nice to see in the rear view.
The machine is in pretty good shape. I hope to swap in an engine this weekend and get it running. Basics are all good, tires have air, seat is ok, and everything moves so far. My son sat on it and decided he would like to keep his 782.
That is if I add power steering to his. He really likes the look of the 782/982. I might add front hyd if the valve from a 3204 can be made to work on it. Should help the value. Am going to keep the Haban deck. That thing is a beast. So far do not see any problems with the deck needing fixed. Starting to like that looks of it. Might be painful to let it go... |
The old story, "Look what followed me home!"
Does that excuse work today? The Ms. doesn't believe me anymore.
Tankman '95 CCC 1641 Eastern PA USMC |
Nice find! Sam has the adapter piece for the spool valve if you need it.
Only 3 left in stock and then no more.
Looking closer there is a fair amount to do to this thing. But still a good buy :-) Plastic looks good on the outside, but I think every mount is broken or cracked. Quite a bit of wear and the PO was not the best with how to do maintenance. Quite a number of not so special fixes. Hyd valve is frozen so must have sat for a while longer than he led to believe. Will take some repair to make it right. Rolled it in the garage and pulled the motor. Big hole in the block. Pic later.
Read up on the Haban decks. (Thanks Sam, you have posted fantastic info) So this one has a few cracks and the rear support is bent requires one of the SamMac mods. Sad the rear tires were pushing the deck enough to cause major wear. |
Feel your pain. The 1862 I just bought has a bunch of broken plastic mounts also. Pretty poor design.
I think I am going to try and counterbore the side panel where I have a broken mount. Then use a rubber expansion nut and bolt it up. I will let you know how it works.
No time this weekend tho. Too much grass to cut before it rains again |
I've used hanger bolts, glued and with a flat washer in the panel.
Only needed 'em on the top "thingys", ugh. Another flat washer and wing nut when the panel is in place.
