Greetings, fellow addicts. I guess this is my first post so here it goes. The 2084 has the infamous kohler CH20 with leaky head gaskets. Bought a Head Gasket Kit from, Repair Clinic Dot Com. turns out my engine has HEAD BOLTS, the KIT is for the one with NUTS. Has anyone got experience with adding STUDS on the BOLTS type of engine? It had occurred to me that if is doable/possible, I would believe that this would be an improvement. Any thoughts/experience on this would be much appreciated. Thank you! Hope I'm not,
Did you get Kohler 24-814-01-S Gaskets...???
24-841-01-S are what I got.
The tag on my engine with model # Spec # etc. is not readable. However I did know that it was a CH20. When I ordered the parts they looked to be right. When I got the parts and did the tear down on the engine I realized that it had head bolts. The kit has replacement nuts with it So, I got on line and found that some have bolts and some have nuts. So my question is can studs be used on this engine, making it work with the gasket kit with nuts. Like adding ARP studs on a diesel engine to replace the head bolts. Has anyone heard of doing this or have experience with doing this?
I just re-used the old bolts on my ch22. The manual says get NEW bolts, they looked fine to me but it's up to you. I just threw the nuts in the toolbox.
- Tim 1872 60" Haban deck- 2082 450 blower, 50c deck - 1450,1650 2x44a deck, QA-42A snowthrower, 70 w/k181(destroyed) 38" pin on deck |
The 2284 rolled out of the factory with this engine:
M/N: CH22 Spec: 66510 Those gaskets you got are correct. I looked this up on both the Cub Cadet and Kohler sites.
I'd think it would be safer to get the right gasket to fit the engine than to modify the engine to fit the gasket.
Great, I am glad to know that I do not have to return the gasket set. Replacement of the bolts was a solution at one time to head gasket issues I believe. Any information on adding STUDS in place of the BOLTS and using the nuts that came with the gasket set possibly, would be greatly appreciated. Thank you all for your help.
| Tags |
| 2084 ch20 head gasket |
