Old 04-19-2010, 09:40 AM
squatch squatch is offline
Default To seal or not?
I'm getting ready to replace the cork gasket between my hydro and tranny. 1st time I used a factory gasket. It seemed to have double sided clear tape on it that was old. It leaked. Second time I used some cork gasket material I had that was a little too thick and sealed it with silicone. It leaked. I now have some of the proper thickness quality cork gasket material and will cut my own. Should I seal it? With what? Normally over the years I have wiped a thin layer of #2 form-a-gasket on most gaskets as a sealer. It normally works pretty well. I don't use cork gaskets often except for fuel tanks. I've been told to install cork dry so it can swell like a wine cork. Opinions?
Old 04-19-2010, 10:33 AM
Don T Don T is offline
I don`t use cork gaskets anymore. I use neoprene and cut out a replacement. I don`t have issues with them leaking. my .02
Old 04-19-2010, 10:51 AM
midyearguru midyearguru is offline
When I'm reassembling componets in a "prone to leak" area, I use HYLOMAR sealant. It ain't cheap, but you get what you pay for.
Old 04-19-2010, 05:21 PM
murphycc
Guest
Posts: n/a
I have replaced several with cork and #2, not a leak one.
Scott
Old 04-19-2010, 08:44 PM
Dave1953's Avatar
Dave1953 Dave1953 is offline
Default Att; Scott Murphy
Scott,
Have been trying to find you. Please contact me at easair@charter.net
Dave Deal, near Hickory NC
