About three weeks ago I ordered two 23X10.50-12 Hi-Run Ag tires from a local big box store. This morning they sent me a message they were ready for pickup. I get there and they only have one tire and no longer available! I let them keep that one since they're so rare.
Anyway, I found a set of Carlisle Tru Powers for a reasonable price. After using the search function I found that a number of guys use this tire, but I figure I better confirm them for my application. No mowing, front end loader, tiller and disc and might be looking for a bottom plow and harrow. They will get filled and run about one hundred pounds of weight on each tire and a potential one hundred and fifty pounds out back. And it's on a 149. Good for all that? |
Absolutely. They're good tires. I have mowed with them for years too, they're fine for that as well.
'74 IHCC 108 - 38A, supersteer axle '75 IHCC 1000 - 44A, Sears wheel weights '87 CC 1872 and 1811 - Haban, 44C '96 CC 1863 - 54GT '79 JD 400 - 60" deck "Projects" '67 123, '65 102, '71 126 |
I agree. I run Ag tires on my 784 and never looked back.
Those are great tires to use for ground (dirt) engaging equipment.
I think the Carlisle will far outlast the Hi-Run. It's money better spent.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I did the same for my 147.
Thanks men! I will order the Carlisle's tonight.
![]() Hello, Today I was mowing my lawn after servicing my B&S 18.5 twin cylinder Engine. About an hour into the cut I noticed a lot of smoke coming out of the exhaust. The engine was also losing power with the cutting deck engaged. When I disengaged the deck the engine would pick up in rpms. I stopped the engine and checked the oil only to find it to be way way over the fill mark and smelt like gasoline. I checked the gas level at the rear of the engine and the tank was empty. Three gallons gone in a mater of one hour. How does three gallons of gas empty into the crankcase in the matter of an hour? Their would have to be a direct path to the crankcase from the tank. The engine starts on first revolution of started. So far: Plugs are new. Pulse fuel pump is working. Drained and removed filter. Put fresh oil and filter back onto engine. I have removed the carb and cleaned it. The fuel bowl had s lot of junk in the bottom. I used carb cleaner on all the jets and ran fine wire thru all the jets. I reassembled the carb and turned it up side down and blew thru the gas inlet and had no air coming thru needle valve I then turned carb back and was able to blow thru needle valve. I did make the mistake of removing the dip stick while engine was running and got covered in gas/oil mixture. Luckly I was wearing my glasses. Checked compression 125 and 150psi Any ideas where the gas is entering the crankcase? |
Sounds like the carb float got stuck wide open.
What "Saturn" said!
She's running rich....
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
